Batch in queue with process flow.
kari_payton
kari_payton
[ FlexSim 17.2.3 ]
In my model I have a forklift taking trash to a big scrap zone. I want the forklift to collect all items in the trash can (queue) and transport. However I'm having trouble implementing the logic.
I am trying to batch incoming items in the queue and send it to a list so the forklift knows what bins need emptying. Is it possible to batch objects created in process flow into a queue in 3D?
I also tried having the forklift request 100 items of scrap and only require 1 item. However it's only pulling 1 item and leaving the other 4 on the list, for example.
Jacob_Gillespie
Here is a small sample model I made. I made it request 100 items but only require 1. The tricky thing is you can't pass an array into the load and unload activities.
batchforklift.fsm
kari_payton
Thanks Jacob!
jason_merschat1
Hi @Jacob Gillespie
This line is very interesting token.i == 1 ? token.pulled : token.pulled[token.i]
Can you explain what this is doing please?
Thanks, Jason
joerg_vogel_HsH
it is the short structure of the statement if (logical condition) true instruction else false instruction.
logical condition ? true instruction : false instruction
Jacob_Gillespie
When you pass an array into the load or unload activity then only the first element of the array is used. So if the index (token.i) is 1 then I made it use token.pulled.
I did it this way because token.pulled is not an array if only one thing was pulled and so token.pulled[token.i] would throw an exception in this case.
philboboADSK
This is known as the ternary operator.
I'm not sure why it isn't documented in the user manual.
Phil BoBo
Sr. Manager, Software Development
