Batch Activity label
gregory_p_chin
gregory_p_chin
In process flow, I have a batch activity with the following settings:
When the max wait timer is fired, I want to release the tokens and change the token label "batchSize" to whatever the current number of tokens were currently batched at time of max wait timer fired (still retaining the "group by" function).
I guess I need a reference to current count of tokens within the batch activity grouped by the label "row" so I can update the "batchSize" label.
jing_chen
Hi!
if check the code in OnWaitTimerFired, you will find the param "collected" which is currently batched at time of max wait timer fired.
You can add a code snippet and type the code as following pic.
gregory_p_chin
Yes, this is it. Thank you...
mischa_spelt
Probably a Set Label also works then, instead of the code snippet.
