basicTE for asrs
basicTE for asrs
avantasia2012
basicTE for asrs
avantasia2012
how can i use basicTE to creat my own ASRSvehicle.For example ,it can be set vertical acceleration ,fork acceleration,thanks
joerg_vogel_HsH
You add a kinematics that animates additional axes of your vehicle. A kinematic has the ability to perform translations and rotations of sub objects on an object. While you setup a kinematic you can define the acceleration, decceleration, speed and travel distance. You get as a return value the time to do the action. And you are able to get information on current speed, time to finish the action and position of the object. Please look into the manual to get further information.
avantasia2012
thanks a lot ,how many sub objects can kinematic has the ability to perform translations and rotations of an object in the same time?
joerg_vogel_HsH
The efficiency of your computer is the limit. Please keep in mind you perform translation and rotation of your sub objects. I still recommend you look into the manual and build your own simple kinematic, that you update in the OnDraw trigger and at the finish time of the kinematic by a delayed message. Please let us know how far you get.
isaac_l1
Hi @liu B
Does @Jörg Vogel's response answer your question? If so, please click the Accept link below the Answer.
Thank you!
