AStar.Cell.getAllocation command crashes
amerloQ2XZU
amerloQ2XZU
[ FlexSim 24.0.3 ]
Hi all,
I need a help with my FlexSim model. It crashes apparently without any reason.
I attached the model to reproduce the issue. You need to open and run it. There is a breakpoint to stop the simulation. If you execute the code step by step, FlexSim crashes on row 10.
Let me know where is my error!
astar_collision.fsm
JordanLJohnson
This issue happens when trying to display very, very large numbers (200 or more digits). Sometimes, FlexSim uses the value DOUBLE_MAX as an error code, which has over 300 digits. When the debugger tries to display this value, it causes a crash in some situations.
This issue has been resolved in version 24.1. It is on the list to fix for version 24.0.
Jordan Johnson
Principal Software Engineer
