Associate a binary parameter to a machine
rocio_alvarez9R3F7
rocio_alvarez9R3F7
[ FlexSim 24.1.1 ]
In this model (it is a FlexSim demo) I have a question:
There are defined binary parameters that are associated with a Dashboard that when a Botton is selected a job is activated and if it is deselected the job is deactivated.
The problem is that I can't find how to relate the parameter to the machine.
I am replicating this model and I cannot make this connection...that is, when I deselect the Botton the machine is not deactivated.
Could you help me find this relationship between the parameter and the machine?
Thanks in advance.
demo-kitting (3)_2.fsm
sebastian_canas9DYX7
Hey @Rocio A,
I modified this model with the GUI. You have to show the hidden objects and select the Source1 and Source2. There is a Trigger On Creation created in both of them. This close the input of the Processor objects if the Parameter values are 0.
Seeing this now, I'd have set this Trigger On Reset, instead of On Creation.
1728572147517.pngHope this helps!
rocio_alvarez9R3F7
Hi @Sebastián Cañas ,
thak you for your information.
