Assigning value from State Tables
petrrais
petrrais
[ FlexSim 23.0.8 ]
I try to create a simple transport simulation. The forklift should transport pallets from queue on "dock site" to a queue on "rack site" (these queues are part of the group "Warehouse_entry"). The queue on "dock site" is filled with pallets from source. Arrival times of pallets are defined in State Table called "schedule". The state table represents import of Excel sheet. In the same table is column "Adresa" which defines on which queue should be the pallet transported.
The issue is... I can't succesfuly assign the value from the column "Adress" to a token and complete transport.
The simmulation throws error:
exception: FlexScript exception: Property "value" accessed on invalid node. at MODEL:/Tools/GlobalTables/GlobalTable1>variables/resettrigger
simple_transport_petrrais.fsm
moehlmann_fe
Observer
Observer
Source1 already assigns the name of the destination queue to a label on the pallet. (Is there a reason that Source2 doesn't?). You can use this to get a reference to the queue on the token.
jason_lightfootVL7B4
Hi @petrrais, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
