Assigning Unique Table for Each Experimenter Replication
kadircan_t
kadircan_t
[ FlexSim 23.2.0 ]
I want to change the number of personnel using parameters and measure the model performance. But I have made each of my personnel responsible for certain queues using a table. For this reason, I will need to use a different table every time the number of personnel changes. How can I do this?
Thank you very much for your support.
Regards.
jason_lightfootVL7B4
There are many ways and the easiest may depend on what you've set up so far, so if you can, post your model.
Each table cell can itself be a table - so one way would be to use the number of people as the row - and then read the cell table in that row.
Hi @Kadircan T,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
