assigning box to certain slot by FlexScript
j08j
j08j
[ FlexSim 24.0.2 ]
I try to store 15 boxes in certain bay, level and slot, e.g. slot(2, 3, 1), by using FlexScript. But it stored all boxes in slot(1, 1, 1), which is not follow the assignment.
Test_1.fsm
moehlmann_fe
Observer
Observer
To assign a slot to an item you need a pointer reference to that item. Which your code doesn't have. This also means that the item must exist in the first place, so you can't assign slots before the start of the model. It has to happen during the runtime.
One option would be to assign the slot in the On Creation trigger of the source. This trigger provides a pointer to the created item.
j08j
Thanks a lot. That's worked fine!
