Assign Regular Expression to variable
jeremy_r
jeremy_r
[ FlexSim 18.2.3 ]
Functions like string.match() and string.replace() can use regular expressions. According to the documentation, regular expressions are actually of the RegExp type. However, RegExp doesn't appear to be a valid type for a variable. i.e. the following code does not work
RegExp expression = /[0-9]/;
Is there any way to assign a regular expression to a variable? Or are all regular expressions required to be defined directly in the code?
The key reason I wanted to do this was to be able to dynamically construct a regular expression in code. Is there any way to do that in FlexScipt (e.g. constructing a string, then converting that string to a regular expression)?
philboboADSK
You cannot dynamically construct a regular expression in FlexScript currently.
They can only be used as literals directly in the code where you are using them.
You cannot store them in a variable, return them from a function, or construct them from a string.
EDIT: If you build up the entire function call, then you can use executestring() to execute it. You can't execute just the regex part though, because you can't return a regex from a function. You must execute the entire function:
string text = "blue cars are really green.";
string findPattern = "/blue/gi";
if (uniform(0, 1) > 0.5)
    findPattern = "/green/gi";
string replaceWith = "red";
var function_with_regex = "eventdata.as(string).replace(" + findPattern + ", \"" + replaceWith + "\")";
return executestring(function_with_regex, 0, 0, text);
Phil BoBo
Sr. Manager, Software Development
jeremy_r
Alright, that's disappointing, but pretty much what I expected. Thanks for the direct answer.
philboboADSK
@jeremy.r
You can wrap the syntax of that example into a user command so that your usage of it is cleaner:
return stringReplaceRegEx("blue cars are really green.", "/blue/gi", "red");
regex_usercommand.fsm
Phil BoBo
