Assign one or two patient destinations
karen_measells
karen_measells
[ FlexSim HC 5.1.0 ]
I'm modeling a primary care clinic, with a rotating set of physicians. I have the patients assigned to a specific physician in the PCI field. How do I specify that each physician is assigned to two rooms per day, and that patients will have to wait if both rooms are full?
Matthew_Gillespie
Here's a sample model of one way you could do that. The main thing I did was make a separate area for each set of two beds. I then have a global table that lists out the different bed areas assigned to each PCI. The Patient Destination field looks up the area in the table they're supposed to go to depending on their PCI.
Matthew Gillespie
FlexSim Software Developer
karen_measells
Thanks. I see how you made the global table, but when I try to make one, I can only put data in the fields - not labels.
Matthew_Gillespie
Do you mean you can put text in the row and column headers, but not in the cells? That's because table cells take number data by default. To add string data to a cell right click on it and choose Assign String Data. You can do this for the whole column at once by right clicking on the column header.
Matthew Gillespie
mhosseini457NG
@Matthew Gillespie How can I do the same and separate the areas in the last version?
Jeanette_Fullmer
Hello @Maryam H2, We suggest you create a new post for your question and reference this post in the new question.
mhosseini457NG
Sure!
