assign a position to the operator at each step of a fluidmixer
roberto_s6
roberto_s6
[ FlexSim 19.1.0 ]
tuberia.fsmIn a fluid model, I have storage tanks that supply material to the mixing tank so I use a fluidmixer. Before each supply step of the Fluidmixer, I want the operator to move to the tank he is supplying to simulate the departure port section. In the step tab you have the option to call the operator, but it only makes it move to the Fluidmixer and not to the tanks as you would like.
I hope you can support me, I would greatly appreciate it since I don't have much experience in flexsim.
regards
tanner_p
You might be able to use my other answer to generate a token that would run a sub-flow. This sub-flow could then Acquire the operator and walk through all of the steps while the fluid mixer is stopped and then start the fluid mixer again after the operator has finished his duties. Just an idea to try, but hopefully it helps.
