ASRS not picking up the item from entrytransfer
miyeDP27D
miyeDP27D
[ FlexSim 24.0.3 ]
The item reached the entry transfer but the ASRS doesnt seem to pick up the item? Also, I have find a slot in the processflow and labelled the slot in the token. WIll the asrs placed it at the slot it is assigned to?
Using ASRS Vehicle to pick an item out_3.fsm
FelixMoehlmann
For a storage object to accept items through a port connection the "Use as Fixed Resource" option must be active. This will also cause the rack to release items when the dwell time finishes. So you might want to set it to not release items and later manually them through port 1 when needed.
Jeanette_Fullmer
Hi @mm_y_2406, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
