arrival schedule problem
sheriff_d
sheriff_d
[ FlexSim 21.0.10 ]
Salut à tous. J'ai un problème avec ma source d'horaire d'arrivée. J'utilise le calendrier sur l'image ci-dessous pour générer des arrivées, mais ce n'est pas le cas de mon modèle. S'il vous plaît pouvez-vous m'aider à résoudre le problème?
allister_wilson
This is what a source table should look like :1648823449160.png
This is what yours looks like :1648823269481.png
In your table, the ArrivalTime is in column 2, it should be in column 1.
Everything is offset to the right by one column.
It looks like you used the Excel importer to populate the table, you need to enable the Use Row Headers checkbox in the Excel import settings, if you have a column on the left containing row names.
ryan_c10
Hi @Sheriff D, was Allister Wilson's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
