Array Index out of bound at Unload in ProcessFlow
sakamoto_ryosuke
sakamoto_ryosuke
[ FlexSim 19.0.2 ]
I'm quite new to FlexSim and I'm trying to create simple simulation as
operator to pick material in order and unload at the sink using processflow.
The error tells me that it us caused by Array index out of bounds at MODEL:/Tools/ProcessFlow/ProcessFlow/Unload.
I try to find some parameter to adjust the size of array, but I don't understand
which array the Unload is referring to. How can I fix this error?
Thank you in advance,
Rick Sakamoto
capture.pngtest-20200129-pickorder-en.fsm
joerg_vogel_HsH
The assign label activity, where you append the token.item to itself, doesn't do what you want.
I suggest you delete this assign strategy there and you use instead a different option in the Pull from List activity.
If you want to reverse the order in the array, there is the method
Array.reverse()
Manual Flexscript Class Reference: Array reverse
sakamoto_ryosuke
Thank you for your reply.
It worked perfectly.
Best Regards,
