Applying new animation to multiple processors in a model
babar_koraishy
babar_koraishy
[ FlexSim 24.0.1 ]
I have a model with many processors (with custom graphics). I created a custom library for these objects, and it has worked well.
Now i want to add an animation to these processors. I dont want to go and replace each processor, its connections etc with a new custom object (which has the animation). Is it possible to somehow 'paste' that animation on to existing objects?
Regards
BK
joerg_vogel_HsH
@Babar Koraishy, try it with tool called edit selected object.
jason_lightfootVL7B4
This script should copy to the selected objects (from Processor1 in this example):
Object origin=Model.find("Processor1");
Object target;
treenode newvisuals= color(origin).up;
Array selobjects=Table.query("SELECT ARRAY_AGG(Object) FROM Objects() WHERE switch_selected(Object,-1)")[1][1];
while (selobjects.length){
    target=selobjects.pop();
    createcopy(newvisuals,color(target).up,1,0,0,1);
    rebindobjectattributes(target);
arunTTT2P
Will this script copy surrogates also?
No - thanks for pointing that out - I'll update it.
babar_koraishy
Thanks, the script worked really well, appreciate your help
