AMR rotation
AMR rotation
chanykE2WUT
AMR rotation
chanykE2WUT
[ FlexSim 22.1.3 ]
Hi in the model enclosed. I would like to have the AGV rotate 180 after arriving at a control point. But I fail to have keep the AGV at that angle after the rotation. I do not want to go by changing the offsetrz, is there any other approach?
David
Jeanette_Fullmer
Hello @David Chan,
The model is not attached. Can you upload it?
chanykE2WUT
I have a problem in uploading the model file.
David
Jeanette_Fullmer
Hello @David Chan,
In the new 22.2 release of FlexSim you are able to set the orientation of the AGV
AGV(token.taskExecuter).isOrientedPathForward = false;
I inserted the above code into your custom code of the model you emailed.
