Algorithm: Repeated simulation of the model.
joe_l6
joe_l6
[ FlexSim 16.1.2 ]
Hi team,
I hope to achieve the following scenario where the model will perform 3 rounds, and in each round, the model will execute 5 tries. Between each simulation, the model will first stop, then reset, and then run again. In other words, the model will run 15 times repeatedly.
At the beginning, I set Round = 1 and Try = 1 in the table, and start the simulation. Before the simulation ends, the next Round and Try values will be written in the table. Afterwards, the model will stop, reset, and run again.
The values of (Round, Try) are in sequence: (1, 1), (1, 2), (1, 3), (1, 4), (1, 5), (2, 1), (2, 2), (2, 3), (2, 4), (2, 5), (3, 1), (3, 2), (3, 3), (3, 4), (3, 5).
My model takes 2 seconds to simulate each time. I have written the following program, but I feel like the model does not spend any time simulating after the first simulation (less than 2 seconds of simulation time). After that, the numbers just keep jumping until the (Round, Try) values are (1, 4).code.png
May I know if my program is written incorrectly? Thank you.Round Try.fsm
jason_lightfootVL7B4
You should use the experimenter for this type of thing (but presumably more elaborate)
joe_l6
Thanks for your suggestion, I'll work on it!
Jeanette_Fullmer
Hi @Joe L6, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
