AGV
AGV
AbdulRaheem
AGV
AbdulRaheem
[ FlexSim 23.0.15 ]
Greetings, I am new user to flexsim. In attached model, I want that: AGV pick up one box from queue and then wait WITH BOX at two control points near to the two operators and then do unloading only at sink. Can somebody help me with that?1.png
moehlmann_fe
Use "On Pre-Arrival" as the trigger point, so the AGV can decelerate to a stop, to prevent the error. To continue, you can redirect the AGV to its previous destination. Then you don't need the NextWorkPoint connections. (There is also a bug in this version of FlexSim: The default setting for the redirect looks for a "NextLookForWork" connection. This was renamed to "NextWorkPoint" in a prior version.
model-ar_1.fsm
AbdulRaheem
Thanks a lot Felix Möhlmann. It was of great help.Thanks a lot.
