AGV travel empty
AGV travel empty
e_yiing98
AGV travel empty
e_yiing98
[ FlexSim 21.1.4 ]
Hi!
There are 2 work flow. 2F1F and 3F1F.
I hope that AGV can support work in 3F after finishing tasks given in 2F.
I used work forwarding point and it works for the first loading and unloading tasks. But then AGV travel empty although there is box to load.
Could anyone give some help, please? Thanks in advance!211101.fsm
moehlmann_fe
If you use work forwarding, the task can only be "picked up" at the control point it is forwarded to. In your case, the tasks for the items at SourceF3 are only available at the forwarded control point on 2F. You can add multiple work forwarding connections though. To have the AGV pick up items on 3F you could also forward the work to the drop off point at the sink.
In addition, the "NextWorkPoint" connections should form a loop. In your current model, if the AGV drops something off on 2F while their is no item to pick up there, it will simply stop afterward because there is no further "next work" connection.
I adjusted your model based on these notes.
211101_1.fsm
connor_a
Hi @Emily K, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
e_yiing98
Your answer is helpful! Thanks for telling me the logic of WorkForwardingPoint and NextWorkPoint.
