AGV throwing exception when loading item
patrick_zweekhorst
patrick_zweekhorst
[ FlexSim 22.2.2 ]
A customer of ours created a model, but it gives a strange exception at time 0. The train AGV just needs to pick up 2 wagons without traveling, but FlexSim throws an error. The strange thing is that the model I created does work. We can’t find the difference why it is working in one model and it isn’t working in the other model. Could someone check what is causing the problem?
Thank you in advance.
Patrick
ModelBaseCase_1g_Not working.fsm
ModelBaseCase_1g_Working.fsm
jason_lightfootVL7B4
It looks like something to do with offset travel - if that's disabled on the non-working model it operates correctly. Should these AGVs be set to use offset travel?
patrick_zweekhorst
@Jason Lightfoot , thank you for looking into. This indeed could be related, but the strange is that is does work with "Use offset travel" in the working model. So, I guess that that should not be the actual problem. Later on in the model the AGV will need to do some offset travel, so it would be good if that would work.
Understood. Yes I reached the same conclusion, so we probably need a developer to take a look.
patrick_zweekhorst
@Jordan Johnson ,
Do you know if this is a bug we can fix or that it is something for the dev list ?
patrick_zweekhorst
@Jason Lightfoot ,
Would you have any idea if a developer can take a look at this?
