AGV process flow logic
ged0313
ged0313
[ FlexSim 21.0.10 ]
I have built a small model, and write down every step the AGV shall follow. But it comes out it can't follow the step i assigned.
1. Load with the wrong number
2. Load and unload at the wrong place
3. Not execute the load/unload activity
Thank you very much for any of your suggestions!
test0624.fsm
moehlmann_fe
Combine the tasks into a single task sequence. The individual tasks you currently have in your Process Flow can get mixed up if you do not define their priorities in detail (but using a task sequence is easier).
While I am happy so see that someone uses lists, they are not really needed here, if I understood your goal correctly. If you do want to keep using lists, I would suggest to not have more than one "List" activity per global list in a Process Flow to improve readability of where the tokens pull from/push to.
test0624_1.fsm
Jeanette_Fullmer
Hi @ged0313, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
