AGV paths disappearing when I add an object from library
sanaz_karamimoghaddam
[ FlexSim 16.2.0 ]
I am trying to make a model using AGV paths, and as soon as I drag and drop a source, the AGV connections disappear. They sometimes appear when I zoom in but I cannot work with them because the come and go repetitively. I faced a similar problem with network nodes. They sometimes disappear or jump to another location. I was wondering if it is due to a bug in the program or if there's anybody experiencing the same issue?
adrian_haws
@sanaz karamimoghaddam Could you please attach a sample model with the stated issues so we can try to replicate them? Also, have you tried going to View->Open Default Workspace?
Hi @Adrian Haws,
agvpathtest.fsm
This is just a simple model that I made, by creating and connecting AGV path into a loop, and then I added a source. As soon as I add the source and right-click / press Esc on my keyboard, the AGV paths disappear. Also, when I save and close the model, and re-open it, I can see both path and source, but as soon as I click somewhere to start working, then the path disappears again. I tried the default workspace as you said, but it didn't work.
joerg_vogel_HsH
@sanaz karamimoghaddam can you reproduce the behaviour of Flexsim on another computer with a different graphic card? If this isn't possible can you install a different software graphic card driver? In this matter it is important to install a version that has lesser features than the current installed one.
Dear @Jörg Vogel, Thanks for your answer. I tried a computer with different graphic card and it worked. I then updated my Software Graphic Card Driver and the issue is solved. Thanks again for your help.
