AGV Network - Issue Allocating Destination If Path/Body Offset
iago_mf
Message 1 of 10
iago_mf
[ FlexSim 23.1.3 ]
Hi!
I was creating an AGV model where, 1 meter before reaching a workstation, I need to apply a lower precision speed than the AGV's usual speed. To achieve this, I created a LoadState called "Precision." So, I used a "travel" activity with a path offset of -1m to travel in the normal load state, and then another "travel" activity to complete that meter in the precision load state. The problem is that I noticed that nothing is being allocated from the last control point before the destination. I'm not sur if this is a bug, but, how could I ensure proper allocation as if I were traveling without a path offset?
I attach an example:
23.1 Not allocating if path offset.fsm
Thanks in advace!
Replies (9)
Message 2 of 10
jason_lightfootVL7B4
Thanks for pointing this out - the lack of control area allocation looks to be a bug with any AGV offset travel (path or body), so I've sent it into the developers.
For now the only suggestion I have is to use standard travel and change the deceleration values such that the final arrival time at the destination CP is correct.
Message 3 of 10
iago_mf
Thanks Jason!
Message 4 of 10
julie_weller
Hi @Iago MF, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
Message 5 of 10
iago_mf
Ups, I've thanked Jason but I forgot to accept the answer. It's done now.
Thanks!
Message 6 of 10
iago_mf
This is still happening in 24.0.0 Beta
Message 7 of 10
kavika_faleumu
Hey @Iago MF, this issue is currently on our dev list. We don't have anyone working on this issue at the moment.
Message 8 of 10
iago_montes_f
Hi, is there any progress on this? It still happens in version 25.0.2
Message 9 of 10
It doesn't look like it from the issue tracker - I'll raise it to check the priority.
Message 10 of 10
iago_montes_f
Hi, any update on this topic?
