AGV Max Allocations through code
sudheer_r
Message 1 of 11
sudheer_r
[ FlexSim 20.1.2 ]
In global table I have control points, Max allocations and Deallocation type, I am trying using this global table how to update this in the model through code.
AGVCP.fsm
Replies (10)
Message 2 of 11
bo_wang
Message 3 of 11
sudheer_r
@Bob.Wang
Thanks for your code. Could you please give feedback on understanding the code of yours for following questions
I'm trying to understand In Table.query command what is Gt1.ROW_Number. What this does actually.
And if(res.numRows<=0) continue; What is this code for ?
res.cloneTo(Table("GlobalTable2")); why are you cloning to Global Table2?
Object agvnetwork = Model.find("AGVNetwork");
treenode an_cPs= agvnetwork.find(">?controlPoints");
treenode an_daT= agvnetwork.find(">?deallocationTypes");
Table gt1 = Table("GlobalTable1");
for(int i = 1; i <= an_cPs.subnodes.length; i++)
    Object cpi_obj = ownerobject(tonode(an_cPs.subnodes.value));
    Table res = Table.query("select *,Gt1.ROW_NUMBER as RN from $1 as Gt1 WHERE [Col 1] = $2 ", gt1, cpi_obj.name);
    if(res.numRows <= 0)
        continue;
    treenode maxAllocations = cpi_obj.find(">?maxAllocations");
    treenode deallocationTypeRank = cpi_obj.find(">?deallocationTypeRank");
    int gt1Row = res[1]["RN"];
    cpi_obj.find(">?maxAllocations").value = gt1[gt1Row][2].as(string).toNum();
    cpi_obj.find(">?deallocationTypeRank").value = an_daT.subnodes[gt1[gt1Row][3]].rank;
Message 4 of 11
bo_wang
Q1:Get the original row of global table 1
Q2:Prevent you from filling in an incorrect CP name
Q3:It‘s for test,You can comment on the code
Message 5 of 11
sudheer_r
@Bob.Wang
You defined gt1 as variable but in Table Query you are using it as Gt1 so got confused. Is both are different or same
Message 6 of 11
bo_wang
gt1-defined for FlexScript and Gt1 for SQL,you can also use $1,like $1.ROW_NUMBER.
They both quote GlobalTable1.
Message 7 of 11
sudheer_r
@Bob.Wang thanks I understood.
In below code why are we using these symbols >? in agvnetwork.find(">?controlPoints);
can't we directly write the code as agvnetwork.find("controlPoints");
does it makes any difference or adding these >? will add any advantage
Message 8 of 11
bo_wang
agvnetwork.find("controlPoints)
is find agvnetwork's child-node that named controlPoints
is find agvnetwork's attribute-node that named controlPoints;
"?" means not limited to the first level.
Message 9 of 11
sudheer_r
@Bob.Wang
In AGVNetwork tree I am looking attribute node controlPoints. But it is not available in AGVNetwork.
Message 10 of 11
joerg_vogel_HsH
Please open the variables branch as stated in comment
and please expand the attribute tree of AGVNetwork and not of object Path1.
Message 11 of 11
sudheer_r
@Bob.Wang Thanks it helped me. Please convert this into answer
@Jörg Vogel thanks for your feedback. I found
