AGV interleaving - Process Flow - Custom Code
juliano_cesar_rv3
juliano_cesar_rv3
[ FlexSim 21.0.3 ]
I built this model by merging AGV movements in a network. This sequence that is configured in the TrainTestv4.fsm model is one of the possible solutions. But my algorithm generated so many others. I would like to test them all.
Is there a way to couple other solutions to the models by importing * .CSV files and using custom code?
I forward the model and one of the * .CSV.
Travel.zip
TrainTestv4.fsm
jason_lightfoot_adsk
Yes you can import it using the Excel importer tool.
When browsing the the file type "*" and press enter to show the .csv.
Choose 0 for the row and 3 for columns. The start row is 2 and you want column headers.
Type the same filename for the Sheet name.
With the file imported you can use a global lookup when assigning the destination labels to a token for use in the AGV move activity.
