AGV Charging by Using time Table.
anutt_k
anutt_k
[ FlexSim 22.2.1 ]
I want to charging AGV from Time Table by reference by this picture.
A green area is a break time. So I want to charging when AGV are break.
What can I do anyway. Thank You.
moehlmann_fe
Observer
Observer
You can define a time table for the charging behaviour. In the "Down Function", instead of stopping the object, you instead have it travel to a charging station.
In the attached example I use the function to send a message to the task executer. A process flow reacts to this message and creates a new task sequence. This sequence has the task executer travel to a charging station and wait there until the duration of the break has elapsed. The charging process is also started in the process flow once the task executer has arrived at the station.
ChargeBreak.fsm
anutt_k
Great. Now I can assign AGV to charging at breaktime for more AGV and more charge station. Thank You.
