AGV battery usage
AGV battery usage
tsuji_ryusuke
AGV battery usage
tsuji_ryusuke
[ FlexSim 22.0.7 ]
Thank you for always answer.
I want to get the battery usage of AGV.
Is there a function to retrieve this? Or should it be calculated from "AGV.amp Hours" or "AGV.battery Level"?
Thank you in advance.
moehlmann_fe
Do you mean the current rate (amps) at which the charge is changing?
You can get that value from the respective AGV's node in the network object.
Object TE = Model.find("TaskExecuter1");
return getsdtvalue(Model.find("AGVNetwork>variables/agvs").subnodes[TE.name], "curAmps");
A negative value means the AGV is currently charging.
Disclaimer: Values in an sdt-node like this may change in the future. So forward-compatibility is not guaranteed.
tsuji_ryusuke
@Felix Möhlmann ,
This is exactly the information I was looking for.
I also understand that the specifications may change in the future.
Thank you for your answer.
moehlmann_fe
I just noticed that the path to the node I use in my answer is suboptimal. It would probably be better to use this variant of the second code line instead (especially for large numbers of AGVs)
return getsdtvalue(TE.find(">variables/navigator/1+"), "curAmps");
tsuji_ryusuke
Thank you for the additional information!
I will use this.
