[ FlexSim 24.1.0 ]
Hi. I'm working on a model that I had working with forklifts but now I converted it to work with AGVs.
But right now I'm facing the problem of charging the AGVs. So when it was on forklifts I knew that they spent a percentage of time charging and I've done that, but with AGVs I don't know that, I only know the percentage they waste per hour and the time they take to charge.
I want to know if there is something pre-made in which I can input the %/hour of battery and the time to charge. And If not, I should create a logic with lists or some sort?
Thank you in advance.
