Advanced Conveyor Control using PF
support5CRPZ
support5CRPZ
[ FlexSim 24.2.1 ]
I make a training model in Advanced Conveyor model using PF.
The phase 2 model shows some issues in the case of buffer conveyors when reversed.
Only one time of the first buffer lane and others show some times reversed.
The conveyor shows 'reverseed' state but the item can't move reversed.
What's the problem of it?
P2_S3_F.fsm
moehlmann_fe
Depending on the floating point math the DPs on the buffer lanes might trigger again when the direction is reversed so the item is stopped again. You can circumvent this by having the trigger based on the leading edge of the item.
support5CRPZ
Thanks.
