[ FlexSim 17.0.2 ]
Hi again,
I wrote a script, which defines for an optimization problem the complete enumeration in the experimenter and also the corresponiding mathematical model in OptQuest.
At the moment, it is nescessary to click on the experimenter and to click also on the OptQuest tab to install the corresponding folders with all the subnodes in the model tree. Only then the script can be activated and will do its job.
Now I am wondering, if there is any command to install a "nacked" experimenter and Optquest instance in the model tree?
(I guess applicationcommand() could be again the solution, but I have no clue, which parameters I have to give to the function)
I am also interessted, if it is possible to save several instances of the experimenter and of OptQuest somewhere in the model tree and to change between those (also by running a script).
Nice regards!
Sebastian
