Add label to token with Process Flow instance information
gesa_r
gesa_r
[ FlexSim 18.0.5 ]
when I have different instances of a process flow e.g. 3 queues, how can I write a label to a token with the information about the running instance.
I know each token is independant but I need to know because some times I want to shut down a specific instance.
Thank you for helping.
joshua_s
Using the reference word "current" points to that instance object. Wherever you are assigning that label, use current.desired_information_here for the value. For example, if you want to shut down queue 2, then you can use the value current.as(Object).name, then have something that looks for the name of queue 2 and then acts upon that information.
