Add copied Objects to A* FR Barrier Problem
s1125413
s1125413
Hello FlexSim Community and dear @moehlmann_fe
I am trying to press a button to produce a layout, and when the AGV encounters the copied layout, it will dodge it to execute the task.
I am also attempting to draw a group called "DIP" in A*, and when I produce the layout, it will be added to the "DIP" group. I would like the objects in the copied layout to become FR Barriers; however, this functionality does not seem to work as expected.
Is there any method to implement this functionality? Thank you in advance for your help and advice!
moehlmann_fe
Add the individual objects to the navigator with the following function:
function_s(navigator, "addMember", object);
s1125413
@moehlmann_fe Thank you, but where should I put this code, I put it in the for loop, but it didn't work.
moehlmann_fe
The first parameter should be the navigator object, not some attribute node of it. And I don't see that you assign a value to "subnode" anywhere.
s1125413
@moehlmann_fe Thanks for your advice and suggestions, I managed to get the model running!
