Add conveyors to a user library: duplicates of visualization types
clair_augsburgerZGWRZ
[ FlexSim 23.0.3 ]
- In a new model, drag & drop 1 straight conveyor and 1 curved conveyor.
- Right-click on the straight conveyor > Edit > Add to User Library > New User Library. It adds 2 items in the library: the StraightConveyor1 object and the RollerConveyor visualization.
- Right-click on the curved conveyor > Edit > Add to User Library > User Library 1. It adds a new item in the library: the CurvedConveyor1 object.
There is no new RollerConveyor visualization added. It makes sense since both conveyors have the same RollerConveyor visualization.
However if you right-click on RollerConveyor in the library > Explore Tree, you will notice that the RollerConveyor type has been added twice:
I think it would make more sense to have only one visualization type here, since both conveyors added to the library have the same RollerConveyor visualization.
Matthew_Gillespie
I'll add this to the dev list. Thanks for pointing it out.
Matthew Gillespie
FlexSim Software Developer
LongG
When you wanna update the same conveyor in library ,it add a new item.I met this question, there can be even more , not just two.
Thanks for your feedback @Long G, that's a very good comment.
@Matthew Gillespie: to reproduce this issue you can also right-click on a conveyor, add it several times to the library to update it, you will notice that it also creates duplicates of the RollerConveyor node:
Matthew_Gillespie
@Clair A This issue is fixed in 22.0.14 and 23.0.5 released today.
Matthew Gillespie
Thanks @Matthew Gillespie !
@Thierry D this issue that you reported to us is now fixed.
