add a new column when pushing a value to a list
marc_r5
marc_r5
[ FlexSim 22.0.2 ]
Hello!
I am using this custom code to push a set of objects inside another object to a list:
Before pushing the object to the list, is not possible to add a value in another new column based on some criteria?
For example, when passing the value, I would want another column with the creationRank, meaning I could use the "i" value in the loop in this new column I would create.
Object current = param(1);
treenode activity = param(2);
Token token = param(3);
treenode processFlow = ownerobject(activity);
for (int i = 1; i<=token.rack.subnodes.length; i++ )
Object inv = token.rack.subnodes;
List("PanelsInRack_ToBeManufactured").push(inv,token.rack);
Thanks!
regan_blackett
It sounds like you want the "i" value to be a Field (column) on the list. The easiest way to do that would be to go to first assign the "i" value as a label to your "inv" objects. Add another line below the variable declaration like inv.CreationRank = i; This will add the label CreationRank to your "inv" objects.
Then you can go to the List properties and add a Label field that looks for the CreationRank label and see their i value on the list's entries table.
marc_r5
That's perfect. Thank you very much
