Acquire Resource Blocking Tokens when resource not in use
sean_p1
sean_p1
[ FlexSim 20.2.2 ]
2020-11-2 Hellam laser-brake-weld Simulation.fsm33897-flexsim-acquire-blocked.pngHey all, I am having a small problem with an acquire resource that is not allowing tokens to pass through it.
Right now i have 4 different part numbers trying to access the same resource, and the 4 part numbers are split into 8 tokens. The Acquire works great with the first 4 tokens. then the second 4 just sit there requesting the resource, when it is not showing that it is in use.
Special thanks to @Regan Blackett in teaching me how to scale this job shop model during my training!
JordanLJohnson
When you run the Laser Process, the token is being run with access only on the parent token. That's a fine option, but when you acquire the laser, that reference is being stored on the "resource" label, just like the operator reference. You need to rename one (or maybe both) of the labels used by the Acquire activities, so you can have a separate label for the operator and the laser.
Also, I noticed you are using getstat() in the Release Laser activity. I think you just want the "Last Acquired" option. Since you only acquire one laser per token, you can use that option to release that token.
Jordan Johnson
Principal Software Engineer
sean_p1
This has fixed my issue. I renamed the resource label for the operator to token.operator instead of token.resource. Thank you!
