Access token label in Resource Node
selvantamil674
selvantamil674
[ FlexSim 23.1.1 ]
Is there is any to access the token label in resource node, without directly Mapping it in resource
Eg : Without using Model.find("OP_1") it need to use token.operator in resource or suggest some alternate
moehlmann_fe
A Process Flow resource represents a static set of objects (or in the case of not using a reference to 3d objects, a static number of virtual resources). The "Reference" field is only evaluated on model reset.
If you want to acquire a specific object from the set then this is specified in the "Query/Object/Array" field of the Acquire activity. As the name suggests, you can enter a query that might filter and/or sort the resource objects. You can reference a single object to acquire. Or you can pass in an array of eligible objects.
