About Transportation
chun_ju_c
chun_ju_c
[ FlexSim 18.1.0 ]
As the model works, the results satisfy my requirement,
I record ABC three queues' current number in GlobalTable1,
The "Flow" option in A, I select "Conditional Port", the following is condition,
current.num > 5 && getdatastat(STAT_MIN, gettablerows("GlobalTable1"), gettablenum("GlobalTable1", count, 3)) < 2
I let the queue which current number is bigger than 5 throws a product to the queue which current number is less than 2,
At the beginning, I let Source1's "Arrival Style" be "Inter-Arrival Time", this option can work correctly,
But when I set "Arrival Style" to "Arrival Sequence", and one arrival with quantity 10, this option can't work correctly, can somebody tell me why?
transportation.fsm
joerg_vogel_HsH
This seems a runtime problem. The items get the state to be releasing the queue. But releasing isn´t the same as exiting or entering another queue. The transfer isn´t finished. The send to port function evaluates on each item the conditional states in the model, there isn´t a change as long as the transfer isn´t complete.
chun_ju_c
@Jörg Vogel, so how can I do for my requirement?
joerg_vogel_HsH
give FlexSim the time to move the items. Create the items instead 10 at a time stamp, create each single item with a small time gap of 1/100 second.
isaac_l1
@Chun-Ju C,
Were you able to find a solution for your question?
