About token.item.labels
3250716938
3250716938
3250716938_0-1788246206913.png3250716938_1-1788246230106.png3250716938_2-1788246240291.png
That flexsim vision is 2027.0.1
I create item and it's labels , but I can't get that labels value, when I used token.item.labels,  in the Flexsim2026, it's can be finish.
FelixMoehlmann
You create multiple items per token, so the resulting "item" label is an array with references to all created items. You get an error when you try to access labels (or other properties) on this array as if it was a single object. The same is true in the 2026 version though, so your model must have worked differently there. I guess there you used the Run Sub Flow activity that is still visible in your screenshots?
I try to create 1 item per token, it's also get an error.  But I got the solution,  used token.item.as(Object).labels,  Set the type of item to object, it's worked.  I did no why. Maybe something change in 2027 version?
Yes, you are right!  I double check that, the problem in array.   Thanks!
