About State Pie chart
Jenny12
Jenny12
[ FlexSim 23.1.3 ]
Somtimes, when I create a State Pie chart, the chart failed to display correctly, as shown in the image below. How should I do?
Thanks in advance!
Dashboard.fsm
moehlmann_fe
When I open your model the chart is not connected to any State Table (though its visible in your screenshot). Maybe try reselecting the State Table from the dropdown menu.
Jenny12
Thanks for responding to my question. I have another question:
After selecting the objects(Machine), it could connect the State Table automatically, but I want to know why it couldn't connect automatically sometimes . And even though the chart is connected to State Table, the chart also failed to display correctly sometimes.
moehlmann_fe
The automatic addition of state tables when creating charts is bugged in the current version.
https://answers.flexsim.com/questions/145593/state-chart-not-updating-state-table-bugoversight.html
I've also seen cases where the generated table doesn't have any states set a "Utilized". I guess you are probably running into one of those issues.
Until the bug is fixed, you will have to double check whether the chart is connected to a state table and whether that table is set up correctly, sadly.
Jenny12
Thanks so much for your responding!
