About ASRS Vehicle
About ASRS Vehicle
tomonori_s
About ASRS Vehicle
tomonori_s
[ FlexSim 21.0.5 ]
The attached model uses an ASRS vehicle for the rack to transport flow items.
I have set an initial lift height, but every time I load a flow item into a rack, it returns to the initial lift height.
Please tell me how to set it to wait on the spot after loading it.
ASRSVehicle.fsm
joerg_vogel_HsH
You have to set and thus you change the initial lift height each time you load or unload items in a pick or place offset task. If this variable gets evaluated at the time when an offset travel begins, then you have to set this value beforehand.
any motion is a result of kinematic. You can test if you achieve the same result by deactivating the kinematic, if loading or unloading are done. This can work if the kinematic node gets initialized each time a new offset travel starts. Otherwise the motion is turned off for the rest of run time of your model.
tomonori_s
Thank you for your reply.
excuse me. I would like to have a sample model based on the attached model because I can not understand it if it is explained only in the text.
If possible, I want to solve it with a simple model, so if possible, I would like something that does not use process flow.
moehlmann_fe
The initial lift height value is stored in the "forkresetheight" node in the objects tree (under variables). You can set its value with
ObjectReference.setVariable("forkresetheight", value)
I'd suggest to do this in an "On State Change" trigger, when the state the vehicle enters is the "unloading" state (and thus before the next travel task starts).
In the attached model you will also find the necessary code to determine the current height of the lift/extender in the trigger option.
asrsvehicle_1.fsm
tomonori_s
It was very helpful. Thank you very much.
