A secuence independent of item type on conveyor
simulaciones_dctc
simulaciones_dctc
[ FlexSim 17.0.2 ]
conveyor-logic.fsmHello,
I hope you can help me. I want that independent of the itemtype the product has to pass to the conveyor of the top part and performs a process, if it is occupied that it is passed to the next unloaded conveyor which will perform the same test and so on.
Thank you
Jacob_Gillespie
Maybe this is what you are looking for.
conveyor-logic-edit.fsm
I used a Restricted Area that only allows a content of 4 items. The conveyor item admitted to the area is then routed to the first open conveyor / stations by checking a block label. After the item finishes with the conveyor / stations, it unsets the block label and exits the Restricted Area allowing the next item in.
