A* Navigator
A* Navigator
IEThai
A* Navigator
IEThai
[ FlexSim 23.1.2 ]
hello
What if I want to use the navigation tool on a building model that has more than 1 floor?
Can you do it? thanks for the reply.
moehlmann_fe
Yes, you can do this. You will have a separate grid for each floor. Connections between these can either be Elevator Bank objects or Bridge paths (you can think of these as stairs in this case). When a task executer is send to a different floor, it will automatically use the elevator or bridge that results in the shortest travel path.
IEThai
Thank you. How to connect the tool How can I set it up?
julie_weller
