A * Navigator does not detect the barriers
omar_aguilera_rico
omar_aguilera_rico
[ FlexSim 19.1.0 ]
Hello! I am working on a model in which I implemented the A * Navigator when doing its construction. I realized that not all barriers are added to the A * Navigator. They appear to me in the Tree as an object and not inside the A * Navigator. How can i fix this?
joshua_s
To throw all your barriers back into A*, run this script
for (int i = 1; i <= content(model); i++)
	if(rank(model,i).name.search("Barrier")==1)
		moveobject(rank(model,i),Model.find("AStarNavigator"));
Can you explain how this occurred? I tried a variety of steps to reproduce this issue but couldn't.
omar_aguilera_rico
Clear @Joshua S! I explain to you what I did. I was really copying and pasting barriers. Place barriers within a plane and some if detected by the A * Navigator and others not. Those were the two activities that I carried out and I realized that what was mentioned above happened. If you think it is necessary for you to share the model so that you can have a look, write to [email protected]
