Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
3D visuals not saving after "Reset"
talia_z
Message 1 of 8
talia_z
[ FlexSim 18.0.8 ]
bottle-unloader-process-v11-with-pulling4.fsm
Hello! I'm running into issues when trying to add dimensions to objects. I currently have two forklifts with dimensions 100x40x45, but when I try to add these dimensions to the other two forklifts they only remain that way (hold the dimensions) until I hit "Reset" and then they revert to their previous, flat state. I would appreciate any advice/help. Thank you!
Replies (7)
Message 2 of 8
jeff_nordgren
@Talia Z
You must have had the Set Object Reset Position activated (right mouse click on object: Edit>Set Object Reset Position). If you Clear that option (right mouse click on object: Edit>Clear Object Reset Position), then change the dimensions. Then re-apply the Set Object Reset Position, it should work just fine (see attached model). When you have the object position set, it remembers ALL the attributes of the object. So when you press Reset, it reverts to those settings.
If you have any problems or questions, please let us know.
Thanks.
bottle-unloader-process-v11-with-pulling4-jn1.fsm
Message 3 of 8
talia_z
Perfect! Thank you so much!!!
Message 4 of 8
ukasz_e
@Jeff Nordgren Hi, I click Clear Object Reset Position, then change the Robot visuals in Animations tab, after that I click Set Object Reset Position and when I click Reset, it goes back to base 3d view.
Message 5 of 8
jason_lightfoot_adsk
Save the base positions
Message 6 of 8
ukasz_e
Thanks!
Message 7 of 8
ukasz_e
@jason.lightfoot but how to save the rotation? Because in animation window, I change the rotation of Robots Joint4 (x on -90 deegres) I save the the base positions, but on reset the rotation goes back to 0
Message 8 of 8
I see you've posted a new question here so we'll stop responding to this thread now.
