3D objects do not grafically follow the logic of the model
ilaria_b
ilaria_b
[ FlexSim 16.0.9 ]
Hi, I don't know why but this situation happens only after long time simulation run, for example 403668.50 sec, and I don't know if is a graphical problem or there's something wrong in the process flow.
In the picture I've attached, there's a station working the object, but the object is not graphically there. When the process ends, the operator instead of picking the object at the end of the conveyor, picks it at the start, and this is a problem for me because i have to evaluate the meters walked by the operator.
The model is attached. ml17-constatistiche-useoperator.fsm
Ilaria
joshua_s
It's because the speed at which you set your conveyors is too high, they are currently set to 3000 times the speed of light. 1000m/s should be just fine for the visuals you want.
joseph_g3
@Ilaria B
Was Joshua's answer helpful for you? Do you have any more questions we can help you with?
ilaria_b
Yes, his answer was perfect, thank you so much!
I posted another question here https://answers.flexsim.com/comments/68045/view.html, can you please help me?
