I would like to consult with you on whether the following two requirements can be implemented. Please find the detailed information below.
1. Directly importing Excel/CSV data into the model I have created an Excel file that replicates the content of the "Edit Table" in the source. I would like to convert this into a CSV file and import it directly, then use that imported data as-is within the model. I suspect that using a "Global Table" might be the approach for this, but I would like to confirm. I have attached the relevant Excel data for your reference.
2. Functionally updating timetable content via data input In the "Production Process" timetable, I have already scheduled Gantt bars representing "down states." Currently, I am inputting these manually while checking the times on the table chart. This method is already quite effective, but to make it more versatile, I want to avoid having to manually drag the Gantt bars to change the start and end times. I would like to know if there is a way to make this automatic—for example, by using labels or a specific table where I can input numbers or dates that then reflect automatically on the timetable.
I would appreciate your guidance on these matters. Thank you in advance for your help.I'm sorry for the inconvenience, but could you please provide the data as an attachment?
