0 as double or int
0 as double or int
michael_m11
0 as double or int
michael_m11
[ FlexSim 20.2.2 ]
Hello guys,
I have a table cell that has a value of 0.000 as a result of a difference between two equal double values.
How can I query that table where cell_value=0 ? It doesn't return enithing.
Looks like int 0 is not equal with double 0.000. Is this a bug ?
Thank you.
benjamin_w2
Hi @michael.m11,
It's hard to know how to help without looking at your model. To receive a more accurate solution, please post your model or a sample model that demonstrates your question.
Proprietary models can be posted as a private question visible only to FlexSim U.S. support staff. You can also contact your local FlexSim distributor for phone or email help.
joerg_vogel_HsH
The difference might be zero at the first visible digits. How do you know the two floating values are the same? Have you subtracted A from A and compared it with zero. Floating point values near zero are a bit imprecise if it comes to be exact zero. Maybe you can query to a range near zero like with the clause BETWEEN value1 AND value2.
philboboADSK
@michael.m11
See also https://en.wikipedia.org/wiki/Floating-point_arithmetic#Accuracy_problems
If you set a floating point value (such as a double) directly to 0, then it will compare to 0 just fine. If a double is the result of a mathematical calculation, it is unlikely to be precisely 0 and you shouldn't compare it to 0 using equality.
Instead of comparing a double to 0, compare whether its absolute value is less than a very small number.
Phil BoBo
Sr. Manager, Software Development
michael_m11
Thank you!
