I am trying to use a Flame 2016.1.1 to give Reslove an AAF, XML, or DLEDL. I prefer to use the AAF so looking on the web, I found the site that explains publishing an AAF. Under "AAF for DaVinci Resolve (Sequence only)" it says you can send the Resolve an AAF with effects. No matter what I try I cant even pull an AAF, XML, or DLEDL back into flame with the effect being in the list. I get resizes but not 2D transforms. I can easily conform the AAF with the Resolve but the effect is not coming across. I think the issue is with the flame side because I cant even bring it back in with the effect. Has anyone ran across this. I want to limit the amount of exports I need to do to save space. I would think a simple z axis move would be no problem. Thanks in advance for you help 🙂
- Vahe -
