Hi all,
Time for another Wacom script. This time I created a setup for launching a simple selector to select wether to use Left-handed or Right-handed orientation. This is mostly for workstations that may have multiple operators.
Please find the most current version of the files on GitHub:
Tested on:
Intuos5 Touch Medium (PTH-650)
#!/bin/bash
## 08/27/20
## Name: CentOS_Wacom_Orientation.sh
## Desc: Some love for the lefties
## Always Current Version:
## https://github.com/flamescripts/Flame_Scripts
## Disclamer: This is not an official Autodesk certified script. Neither the
## author nor Autodesk are responsible for any use, misuse, unintened results
## or data loss that may ocurr from using this script.
## Use at your own risk. Script intended for providing guidance only.
## IMPORTANT: If using script remotely via ssh, be sure to export the DISPLAY
## ex: export DISPLAY=:0
## Installation:
## 1) Extract and copy "Wacom-Hands" folder to /opt/Autodesk.
## -- If you place the "Wacom-Hands" folder in a different location, you must
## update the following 2 lines in "CentOS_Wacom_Orientation.desktop" or this
## script will break.
## -- EXAMPLE: Exec='/opt/Autodesk/Wacom-Hands/CentOS_Wacom_Orientation.sh'
## -- EXAMPLE: Icon='/opt/Autodesk/Wacom-Hands/CentOS_Wacom_Orientation.png'
## 2) Copy CentOS_Wacom_Orientation.desktop to Flame User's Desktop.
## Usage:
## Double Click the hands icons named Wacom Orientation on Desktop
## --Select 1 for Left-Handed Orientation
## --Select 2 for Right-Handed orientation
# Variables
STYLUS=`xsetwacom --list devices | awk '/STYLUS/||/stylus/||/Stylus/' | awk -F "id:" '{print $1}' | cut -d " " -f1-8 | sed -e 's/[[:space:]]*$//'`
# SSH DISPLAY
if [ -n "$SSH_CLIENT" ] || [ -n "$SSH_TTY" ]; then
clear
echo "It looks like you are using a remote shell, this script should be modified if you are automating to remove interactive portion."
echo "You MUST also export display if errors occur: '${bold}export DISPLAY=:0'"
read -n 1 -s -r -p "Press any key to continue"
fi
# Reset console
clear
# Model IDs and current Rotation setting
echo 'CentOS Wacom table orientation script'
echo 'STYLUS:' $STYLUS
echo ''
echo 'Tablet rotation is currently set to:' `xsetwacom get "$STYLUS" rotate`
echo ''
## Select Orientation
echo ''
echo "Enter (1) if you are Left-handed or Enter (2) if you are Right-Handed or Enter (3) to Exit w/out changing orientation"
echo ''
select hand in Left-Handed Right-Handed Quit; do
case $hand in
Left-Handed)
echo ''
echo 'Switching to Left Handed orientation'
xsetwacom set "$STYLUS" rotate half
break
Right-Handed)
echo ''
echo 'Switching to Right Handed orientation'
xsetwacom set "$STYLUS" rotate none
break
Quit)
echo 'Quiting, no changes made.'
break
echo ''
echo "Invalid option $REPLY, Please select a number between 1 and 3"
esac
done
There appears to be a wrapping issue in the codeblock. I recommend downloading the raw directly from github. If you are copying and pasting, there may be an issue.
