Announcements
Using HP RGS with flame
liam.naerger
Observer
liam.naerger
Observer
Observer
Hi All
Currently set up hp rgs for remote users on flame, it works great apart from I cant get the application audio out through RGS. I have audio from the machine/firefox ect.however I need to get audio out of the flame application. Nothing in audio setting or flame settings that isnt alsa/nvidia or kona.
Has anyone got this working?
Replies (12)
fred.warren
Hello @liam.naerger,
The following was posted by one of our support agent, Fernando Novo, on the Facebook Logik group:
HP RGS Linux provides a script to setup the Alsa audio:
/opt/hpremote/rgsender/audio/rg_alsa_config.sh alsa
This will allow you to use Alsa when you are connected to a Flame family Linux workstation.
In Flame Setup, Audio Device must be set as "Alsa" and Video Device must be set as "None".
There is also a Sender Config App to setup all the HP RGS parameters (run it as root):
/opt/hpremote/rgsender/senderconfigapp.sh
IMPORTANT NOTE:
HP RGS is a software provided by HP.
Autodesk does not support it.
Autodesk does not warranty the audio quality neither the playback performance while you are using HP RGS software.
Please accept this as a solution if you feel your question has been answered.
fred
Frédéric Warren
User Experience Designer
liam.naerger
Observer
Observer
  Its set as Alsa in flamesetup
what should it show up as in the flame options?
I enclosed a screen capture
fernovo
Autodesk Support
Autodesk Support
Please use the option "loopback loopback PC".
Make sure that you in Flame Setup application the video device option is set to "none".
kai
Thank you for helpful guide.
I ran the script /opt/hpremote/rgsender/audio/rg_alsa_config.sh alsa
and configred Flame to use ALSA and no video
I have selected "loopback loopback PC" in Flame audio, but when I hit play nothing happens (freeze frame)
I get this message in shell:    AUDIO: Unable to start playback: Invalid argument
If I uncheck "Stream audio from Sender" on the Receiver, Flame playback works with no audio.
Do I need to change something on the Receiver?
I'm on Z820 with RGS versjon 7.6.1.19438 and Mac receiver
/Kai
jeffrey.ramirez
Hi kai,
I hope you are doing well.
Have you tried rebooting your Flame machine after running the script below?
What is the DKU and Flame version installed?
Jeff
kai
Hi Jeffrey,
Thank you for looking into this.
I found some more information on Logic about this so it's working.
Just restarting Flame after selecting the lower “loopback PC” in audio settings solves the playback issue.
But RGS really needs to support 48KHz for the audio to be useful. The audio speed is to slow and out of sync 😞
/Kai
jeffrey.ramirez
Hi kai,
If you are not aware yet, HP have released a patch to support 48KHz.  Please contact HP for this matter.
https://knowledge.autodesk.com/article/How-to-output-48kHz-audio-using-HP-RGS-in-Flame
Jeff
kai
Thank you Jeff,
Yes I have received the script from HP, so its working now 🙂
/Kai
I dont have the option “loopback PC”.
Is there anything I need to do?
Flame Linux 2020.3
kai
Did you run the script for Alsa audio? Script name "rg_alsa_config.sh"
sh /opt/hpremote/rgsender/audio/rg_alsa_config.sh
You also need to edit flame init.cfg to disable aja video, aja audio and enable ALSA audio
Audiodevice ALSA
You should see "loopback PC"
On my machine I have two loopback PC and I had to select the lower
Exit Flame and start again. You should have audio on your RGS
/Kai
kai
Hi again,
You will also need a script from HP solving the 48kHz audio problem with audio going out of sync.
You can sign up and post a message here:
https://h30434.www3.hp.com/t5/HP-ZCentral-Remote-Boost-and-Connect/Autodesk-Flame-Reference-is-44-1k...
/Kai
engineering
Observer
Observer
Hello
We have set the '48' flag on the alsa config. But it appears to have broken the ability for some to hear the audio from their flame.
Is there a step i'm missing?
thanks
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
